1978 - 1996 Big Bronco
Where's the amp?
Old Sep 4, 2001 | 01:04 AM
ricciardelli's Avatar
ricciardelli
Where's the amp?
Does anyone know where Ford decided to hide the amp for the premium sound system in a '95 EB Bronco?
Old Sep 4, 2001 | 01:20 AM
ecarter50's Avatar
ecarter50
Where's the amp?
If it's the same as a F150 on the firewall a little lower and to the left of the radio.
Old Sep 4, 2001 | 01:32 AM
ricciardelli
Where's the amp?
Thanks for the reply...I would have thought that it would be in the same location as the F-150...but...I didn't see it there...and I have tried to trace the cables, but run out of finger room real fast!
Old Sep 4, 2001 | 11:48 AM
beratte's Avatar
beratte
Where's the amp?
According to the Ford books it's behind the radio, up under the dash, in fact, I've seen mine there now that I think about it. Good luck.
Old Sep 4, 2001 | 12:06 PM
ricciardelli
Where's the amp?
Thanks for the response...
I think I may have found it...and it is not behind the radio (the only thing there is a ton of A/C ducting.)
There appears to be something, maybe the amp, located on a flat panel just above the gas pedal. It has 2 connectors, multi-wired, and on the top side I think I felt heatsinks...can't tell for sure until I get those connectors released and see if they fit the bypass cable I have. (But that is going to be tough, since there is no finger room...)
Old Sep 4, 2001 | 12:35 PM
georgedavila's Avatar
georgedavila
Where's the amp?
