TRW pistons good enough?
Old 04-23-2007, 08:56 PM
dogsniper's Avatar
dogsniper
dogsniper is offline
I am wondering everyone seems to agree that for real power give my 390 10 or 10.5 to one CR then a good size cam to bleed off sme cylinder pressure. And have .012 deck height. But trwlz291f pistons won't even reach 10 to 1, I can't find a piston to meet all these criteria. These pistons plus my c8ae-h heads 71 cc will only be about 9.2 to 1.
Any ideas??
Old 04-23-2007, 09:47 PM
fastfarmer's Avatar
fastfarmer
fastfarmer is offline
I'm building a 390 with the TRWs for my 76 F150. Heck, I'm just happy to have more compression than the 7-something- to- one in my current 360!
Old 04-23-2007, 10:29 PM
rusty70f100's Avatar
rusty70f100
rusty70f100 is offline
According to my calculations, those pistons (TRW-L2291) with 71cc chamber volume, .030" overbore, and Fel-Pro head gaskets, give you 9.6:1 compression. If you use .020" steel shim head gaskets, you get about 10.2:1.
Recheck your calculations.
Old 04-23-2007, 10:35 PM
dogsniper's Avatar
dogsniper
TRW Pistons
What about deck height it's kinda important to be around that .012 instead of .031 or so isn't it?
Old 04-24-2007, 05:41 AM
RapidRuss's Avatar
RapidRuss
RapidRuss is offline
FE "Freakin Expensive"
Well Deck height and chambers size and gasket thickness..
RJ
Old 04-24-2007, 11:06 AM
rusty70f100
TRW L2291's have a 1.776" compression height.
Stock FE deck height = 10.17"
390 crank throw = 1.892"
390 rod length = 6.488"
Doing some simple math:
10.17-1.892-6.488-1.776=.014" deck clearance
When I put my 390 together with TRW L2291's, it had a deck clearance of .012". Close enough to the calculation.
Most Fel-Pro head gaskets have a compressed thickness of .041" and a diameter of 4.4". Look up the specs on your desired gaskets to get more accuracy there.
Now go here and plug in your numbers:
http://www.kb-silvolite.com/calc.php?action=comp
Nick-1973-ford
03-05-2017 06:38 PM
Romel77
23
02-11-2016 06:13 AM
BigBlocker0248
01-17-2016 03:20 PM
kellar
18
11-09-2007 07:40 PM
shortbed1
08-17-2006 08:36 AM
Quick Reply: TRW pistons good enough?
