Gpr Switch.
Old Apr 23, 2007 | 08:13 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question Gpr Switch.
Plowhand, after reading some about the gpr switch I am confused because you wrote to me time ago:
RÖENTGEEP, to do the glow plug switch, locate the glow plug relay (looks like the starter relay thats on the fender) on the front right (passengers side) of the engine, under the cover. There will be two big wires and two small wires, disconnect the two small wires or unplug them if yours has the plug. With a volt meter or test light, find the one that has power when the key switch is turned on. Cut this wire, add enough wire to go inside the cab to the dash, attach a switch, run wire back to the other end of the cut wire and attach. Re-connect the two small wires to the relay. Your "Wait to Start" light will still come on, but your glow plugs will not have any power unless you flip the switch.
And later to Yokounsly :
So one of the easiest fixes for your problem that I have done before is: turn your key on and check to see if you have power on one of the small wires to the GPR. The other small wire should show a ground, if it does not then the PCM is not completing the circuit. Take this wire, cut it, splice into it (I would run two sizes bigger "lower #") and run it to a switch (that you mount in your dash) then to a small 12 volt LED light (color of your choice) then to a good ground. The switch could be a momentary one if you want to hold it in until you start or a regular one (the regular one will keep your glow plugs on until you turn it off, so don't forget to turn it off). Hope this helps.
The questions is cut the hot wire or the ground wire?
Old Apr 23, 2007 | 08:29 PM
plowhand's Avatar
plowhand
Playing in the Dirt
RÖENTGEEP, both of them work, but the first way, the one that I told you, lets the PCM turn off the glow plugs if you leave them on. If I remember correctly in talking with you then that was what you were looking for.
The second way, the one that I told yukonsly, you have total control over the glow plugs and as long as the switch is on the glow plugs are activated. If you leave the switch on for two hours the glow plugs are on for two hours.
So, pick the one that is best for you.
Old Apr 23, 2007 | 09:26 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Well I continue with the first one, because our memory also has a lot of miles, right?
thanks again
Old Aug 14, 2007 | 01:31 PM
powrstrkr's Avatar
powrstrkr
This is an old post but I'm getting ready to do this mod. How many amps should the switch be rated at? I'm thinking not very many as it's on the primary side of the relay.
Old Aug 14, 2007 | 01:57 PM
Neal 97 250's Avatar
Neal 97 250
I would say a regular 20 or so amp switch will work maybe even a little smaller.
Old Aug 14, 2007 | 02:04 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
I used one of 15 A
Old Aug 14, 2007 | 04:01 PM
powrstrkr's Avatar
powrstrkr
Thanks guys. I'm hoping to get my CCV mod, GPR switch and rear air bags on before a wheeling trip to Utah in early Oct when I'll be hauling toys again.
Old Aug 14, 2007 | 06:25 PM
skittlejr's Avatar
skittlejr
seems to me, positive or ground, all u are doing is interuppting the circuit to disable the gplugs. with the switch in the on position, everything should act normal. this would only apply to overidding the glowplugs not fixing a problem.
bismic
Mar 9, 2022 09:20 AM
myakkacracka
13
Jun 16, 2016 11:33 AM
scott78f2504x4
Ford Truck Parts for Sale
54
Aug 25, 2014 06:26 PM
myakkacracka
Mar 17, 2014 07:35 AM
Jeffypop
Jan 25, 2007 11:42 PM
