highboy headers
Old Apr 23, 2007 | 07:53 PM
highboy1975's Avatar
highboy1975
highboy headers
i have a 1975 highboy with a hp d60 in it. i want to run a set of headersin it, but i dont know what would fit, any suggestions? hedman makes a header for highboys, but its a full length and i dont know if my dif will hit the header. it's already smacked the stock exhaust pretty good.
thanks
Old Apr 23, 2007 | 09:22 PM
eveready77's Avatar
eveready77
I'm not shure of the measurements on the dana 60 but my '73 hi-boy with the stock dana 44 clears the hedman's just fine. Ordered from summit and have had no issues at all. Install was a bit trickey IIRC but overall went in fine. I havent had any leaks yet either. Don't know if this helps but it's all I can contribute.
Old Apr 23, 2007 | 09:30 PM
marcs724's Avatar
marcs724
I run the L&L fenderwell exit headers on my 77. It has a 460 and a hp 60 front as well. no problems. The L&L headers are $$$$ but they are very well built, and have a lifetime guarantee against rust-through IIRC.
Old Apr 24, 2007 | 02:14 PM
highboy1975
i checked out the l&l headers, they don't make anything for the fe motors.
Old Apr 24, 2007 | 09:30 PM
hotroddually's Avatar
hotroddually
a few years ago,i put headman headers on a highboy (fe engine, np 435 trans,d 60 front). i dont remember the part number though.they fit fine,the trucks suspension was stock too.i remember having to jack up the engine,remove the passenger side motor mount,to get the tubes around the motor mount,but it was not as bad as it sounds.
Old Apr 25, 2007 | 04:33 PM
u150md's Avatar
u150md
i am running headman headers on my 68 highboy with stock suspension.front driveshaft has hit left ext pipe once or twice,but has never hit the header
Old Apr 25, 2007 | 05:14 PM
highboy1975
thanks guys, looks like thats a go then
