mixing methoxide?
Old 04-23-2007, 10:38 AM
superpony18's Avatar
superpony18
superpony18 is offline
mixing methoxide?
I am just about done building my processor and was wondering how everyone is mixing up their meth and lye.
Old 04-23-2007, 11:03 AM
Murphy2000's Avatar
Murphy2000
Murphy2000 is offline
Depends on your processor size.
For small stuff, just use a plastic drum.. I use a 15 gallon poly drum and just dump KOH in through a wide mouth funnel.. I then use a piece of 3/4 pvc pipe to mix it all up.
The whole process takes about 5 minutes. You must monitor heat generation and on a hot summer day, you might have to slow down the mixing to let some heat dissipate. I don't have any fume control and since I have an open hole I'm mixing through, I do this outside.
I'm moving up to a 200 gallon processor that will require something different.. I'm thinking of pump mixing and a stainless tank to take the heat.
Old 04-28-2007, 10:21 AM
Talyn's Avatar
Talyn
Talyn is offline
Murphy, you should be carefull doing that in plastic, and with PVC.
Methanol will eat it up.
Old 04-28-2007, 05:58 PM
Murphy2000's Avatar
Murphy2000
That information is incorrect.
1. My methanol comes in plastic 55 gallon drums.
2. Methanol and PVC work just fine together.. Rating is "EXCELLENT"
Not sure what you are talking about.
I use methanol with PVC frequently.. never a problem or even a hint of one.. (I use Sch80 pvc.. the dark grey stuff)
The only thing you need to worry about when mixing methanol and lye in a plastic container is heat. The process of mixing the two creates lots of heat so if you have high titrating oil, you may want to mix only half of your lye at a time..
patrickke
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
13
11-08-2010 11:03 AM
bamacommander
2004 - 2008 F150
21
01-24-2008 08:02 PM
jcs1966
09-07-2004 04:18 PM
Gwilkrrs
12-29-2002 08:33 PM
fatfenders
Oil & Lubrication
10-02-2002 03:47 PM
Quick Reply: mixing methoxide?
