Do IDI engines require gp's by design?
Do all IDI engines require a glow plug system to start properly? What is the advantage of an IDI engine over that of a direct injection engine?
IDI's usually have glow plugs..............(all most a basic requirement in colder climates)
DI usually have intake air heaters.........(all most a basic requirement in colder climates)
advantages of IDI (usually)
can run on a lower cetane fuel than a DI much easier..........
lower emissions
much easier to build smaller CID engines
wider range of torque band...
just a little bit quieter (diesel knock)
if turbo, requires less boost to get equal cylinder pressure as DI
can be much farther out of tune and still run ok.............
advantages of DI (usually)
easier and Much cheaper to build in larger CID engines
lower compression ratio, makes for easier cold starts....
it is claimed to get better fuel mileage (rare case indeed)
crossbones
There is a big design difference between a precombustion chamber and a turbulance chamber. Precombustion engines only send about about 30 to 40% of the compressed air fuel into the chamber and turbulance chamber engines send pretty much all of the air fuel into the chamber.
The glowplugs are a must on a turbulance chamber engine for cold starts. The reason is that to get diesel to light the air has to be between 1000 and 1100 deg. That number can vary some because of different types of fuel but that is the accepted number by most diesel motor manufactures. The reason that they need them is because the heat generated by compression in the cylinder area doesn't transfer to the turbulance chamber to start when cold. The cylinder area and the chamber aren't in the same piece of iron and they are seperated by a gasket. That is the key. The air looses it's ignition temp fast.
6.9's and 7.3's have turbulance chambers not precombustion chambers. The pistons are flat in them just like a gas motor where as the precumbustion engine and a DI motors will have a combustion chamber built in the piston.
They have added glow plugs to later DI engines to try to eliminate white smoke at start up and to help start on cold days.
Yes, we use the wrong terminology on the forum but it really doesn't matter. That is actually how it is but unless you are going on Jepardy it may not matter much.
One other thing to note. These engines, if they are in good shape, don't have to have the glowplugs cycle at every start up. My truck has been on a manual switch for 8 years and I don't cycle them everytime I start it up. During the summer I can go into work in the morning and go out at dinner time and it will start right up without cycling the plugs. I just know my motor. I guess that is why have had the same plugs in it for 8 years and they still are fine. They are AC 8G's.
The guys over on the Mercedes board gave me a snotty reception for this mod, funny thing is on that board EVERY winter there are dozens of posts about bad starting and glowplugs. That conroler costs about $270!
Steve
