Whats This??????
Old Apr 23, 2007 | 12:20 AM
fixnair's Avatar
fixnair
Smile Whats This??????
Under my dash at the OBD 2 connector there is a small push button. It is located on the OBD 2 bracket just above and to the left. Pressing it, as I looked at the instrument panel for some change, I see only the Odometer numbers dim.
Anyone have any clue as to what this thing does?
Steve
Old Apr 23, 2007 | 05:08 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Good question. I can find no such button on mine. Does it have an aftermarket alarm or something?
Old Apr 23, 2007 | 05:12 PM
totin_tools's Avatar
totin_tools
When I had the keyless entry on my truck I had a button similiar to that. It was for the bypass start in case the brain quits working in the keyless system. Just a thought.
Old Apr 23, 2007 | 05:25 PM
fixnair's Avatar
fixnair
Yes it does have an aftermarket alarm but this thing sure looks like an intergral part of the OBD 2 bracket. Thanks for the replies.
Steve
Old Apr 23, 2007 | 05:30 PM
SpringerPop's Avatar
SpringerPop
Valet-mode switch?
Pop
Old Apr 23, 2007 | 06:29 PM
HP junkie's Avatar
HP junkie
If I remember correctly it would be an override switch for the alarm in case your remote went south. It would let you start the truck by pressing the button and a number of key turns on the ignition or vise versa. You might want to check out what kind of alarm you have and see if you can find a manual of some sort to be sure.
Old Apr 24, 2007 | 03:07 PM
fbilly420's Avatar
fbilly420
sounds like an alarm override switch to me. OBD II connectors should only have diagnostic plug on them
Old Apr 25, 2007 | 12:26 AM
fixnair's Avatar
fixnair
I had occasion to be under the dasboard again today hooking up the water control valve on the heater circuit. Geting ready for hot weather. Supposed to be 90° here Friday. I followed the wiring back from this pushbutton and you guys were right, it is part of the alarm system. The alarm system does not work so I cannot tell you what it does but thanks to all who responded.
Steve
