You should see a bit of a drop in EGT's it you have a pyro and it may run a bit cooler by the temp gauge also. I did see these results when I did the pipe on my M/H. I never see over 10lbs on the boost mostly 3-5 when cruzin but will climb to 7 on a hill. I just think it counds a LOT cooler
Stock is 2.5" and the downpipe was run over by at least 3 fork trucks before it was install.
The ATS upgrade increases the downpipe to 3" round pipe.
That drops the EGT and lets the turbo spool faster.
Increase every piece of pipe you can with 3" pipe, delete the muffler.
You can also pick up a bit more power by working on the air intake to the air cleaner.
