turn signal
Old Apr 22, 2007 | 10:19 PM
downunder0323's Avatar
downunder0323
turn signal
I have a 1986 Ford F-250 6.9L diesel.
I put a new cd player in my truck about 3 months ago and about a month ago my turn signals were having problems so i replaced the the turn signal switch but still no good and now when i replace a fuse it blows everytime, the problem is mostly the right turn signal. any thoughts.
Old Apr 23, 2007 | 08:57 AM
Franklin2's Avatar
Franklin2
What is happening exactly?
The left signal works normal front and rear?
The right signal does not work at all? The lights come on but they don't blink? Only the front or rear on the right work?
Do both rear brake lights work?
Which fuse blows?
Old Apr 23, 2007 | 03:19 PM
adrianspeeder's Avatar
adrianspeeder
How bout the four ways?
Is there an aftermarket trailer hitch connector wired in with questionable skill?
Adrianspeeder
Old Apr 23, 2007 | 03:48 PM
downunder0323
turn signal
the left side works unless of course the fuse is out but the right rear doesn't work and the right fornt will blink realy fast.
Old Apr 23, 2007 | 05:28 PM
Franklin2's Avatar
Franklin2
Does the right rear brake light work? The reason for so many questions is the right rear turn and the right rear brake light are the same bulb and wire. So if the brake light works, then your problem is probably going to be the turnsignal switch. This is were the brake switch signal and the flasher signal get mixed together onto the one wire going to the rear.
Old Apr 28, 2007 | 03:44 PM
downunder0323
fuse help
my turn signal and brake light fuse is constantly blowing and i dont no why it is a 15 amp fuse.
and i think the line is shorting out somewhere any ideas.
1986 ford f 250 diesel
