Missing diesel power?
Old Apr 22, 2007 | 06:34 PM
dugger91's Avatar
dugger91
I just got my first diesel a 1989 f350 with a 7.3 diesel motor. I took out my trailer today to see how it would do and was extremely disappointed with the pulling power. I could barely maintain 55 mph on flat ground. The truck has 188,000 miles on it, and I think 4.10 gears in the diff. Do you have any suggestions on what I can do to make it pull better? I only use this truck to pull my trailers, a flat bed with atvs on it or a 22' toy hauler when we go camping. I am taking the truck to a mechanic to check out a knock that sounds like it is coming from the bottom end. If the motor is shot should I rebuild it or just buy a crate motor? Any help is greatly appreciated.
Old Apr 22, 2007 | 06:55 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
First off - welcome to the diesel family.
Second lets see what we've got. Do you know when the last fuel filter change was? If don't know then change fuel filter. Could be starving for fuel. Also Put diesel kleen in the fuel as these older engine don't especially like the new ultra low sulfur diesel (ULSD) that came out last year. It will run but not as well as the low sulfur fuel. If you have it commercially available in your area try some biodiesel. I've used it in everything I own on the farm and it has worked very well especially in older equipment and trucks.
I try to use the cheaper methods of repair before going to costly.
Old Apr 22, 2007 | 08:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
ULSD also tends to loosen all the varnish and deposits in the fuel system.
When they reach the fuel filter, they can plug it up.
At 188,000 your engine should not be shot if it was taken care of.
The fuel injection system may be due for some repairs though.
FlTruckGirl
28
May 2, 2013 12:48 AM
daren99
Apr 27, 2012 07:40 PM
2003xcrsn4x4
13
Jan 21, 2011 10:49 PM
mach6-300
56
Sep 30, 2010 06:05 PM
excaliber551
2009 - 2014 F150
125
Nov 28, 2009 05:27 AM
