tail light question
white: reverse light
brown: tail light
red: brake light/ turn signal
I have everything but revese lights that work... I try and try but I cant get reverse lights to work. And it is grounded out. thanks for the help!!
Black/Red stripe = BU lights
Brown = License plate and running lights
Green wire - Right TS/Brake light
Light blue to Green Left TS/Brake light
If you jumper a 12v powered wire to the BU circuit Black/red stripe and the lights come on doing this test.......
The NSS/Back Light switch mounted on the transmission is probably filthy and stopped working.
Do a word search for "lacquer thinner" in the message box with my user name in the 73-79 forum and you should see how to clean it.
Or just replace it if you're rich
