1978 - 1996 Big Bronco
gear changes for 32" tires?
Old Sep 19, 2001 | 06:49 AM
bn's Avatar
bn
I have read a lot of the past messages about putting 32s or 31s on a Bronco without a lift. Should gears be changed for either of the size tires?
Old Sep 19, 2001 | 06:28 PM
83Bronco's Avatar
83Bronco
What size tire are you currently running? You wont need to change gears if your gears are 3.55. To found out look on the sticker on the drivers door. On my 83 Bronco it came from the factory with 31x10.5 on it. Gear Ratio/Tire Size Calculator is also a article in the tech articles that will tell you if you need to change your gearing.
Old Sep 21, 2001 | 09:08 AM
Rodeojoe's Avatar
Rodeojoe
bn, When i changed tire size on my 96 Bronco i put 32's on. The stock tires are only 1" smaller in diameter than 32's. I did not make any gear changes. Rodeojoe
Old Sep 24, 2001 | 12:26 AM
Riso79's Avatar
Riso79
Gear changes really aren't necessary but you will notice a difference in the pick-up. What you really need to do is adjust the speedometer and it will help alot. The 3.73 gears are perfect for the 32" tires.
Old Sep 24, 2001 | 12:44 AM
honney's Avatar
honney
