I beams
Old Apr 22, 2007 | 08:40 AM
68shortbedmo's Avatar
68shortbedmo
I beams
Is the 73 I beams longer than the 68's I just put I beams and all on my 68 for my disc brake conv. the front end dosent appear any wider but my front clip isnt on either I was curious if my fenders would clear the tires
Old Apr 22, 2007 | 09:22 AM
wizzard351's Avatar
wizzard351
should be the same just w/disc
Old Apr 22, 2007 | 09:29 AM
68shortbedmo
cool I didnt know for sure other than I thought they widened the frames in 73 so I didnt know if they lengthened the I beams too
Old Apr 22, 2007 | 10:39 AM
jowilker's Avatar
jowilker
The frame was widened under the bed.
John
Old Apr 23, 2007 | 10:22 AM
FordBoypete's Avatar
FordBoypete
Thumbs up
John is oh so very correct.
If you look closely rear axle assy track widths, they're narrower than front I Beam track widths on all 1965 thru 1972 light & medium duty F series trucks. Blow ties are they same way except they kept them unequal into the 80s or 90s
When FoMoCo Added the 1-1/2 Inch per side [+3" total] increase to widen the frames from 1973 & later, they actually only made both axle track widths on 4X2 trucks equal. Better handling with a load, trailer, camper, or cross winds was the objective I believe. Some folks say it was to accomodate the wider in frame Fuel Tank, but I doubt that, It was all about safety & handling with various type of loading conditions.
FBp
