I'm sure that this has also been brought up before, so forgive me if it has (search not working [?]).
Anyways, the emblems (on fenders and tail) are starting to lose some of their luster, and I'm kinda tired with their somewhat plain/ugly look. Any ideas? I read about acetoning them - would this be a good idea?
Has anyone swapped out to the newer badges? I like the looks of those, but I'm not sure if they'd cover up the holes in the fenders.
yeah, the more i look at the newer model's badges the more I like them - the chrome with black writing that are about 1.5" tall by maybe 4" wide (just guessing from memory). I basically wanna know if they'd cover the holes in the fenders... anyone?
If I recall correctly, there was a small debate a few months back about this, but I can't seem to find the threads as of right now...
According to whomever, there are (or should be) 2-3 holes in the fenders which the badges cover... if this isn't true, I guess I have nothing to worry about (except maybe a little sunfade around where the badges were).
Can anyone end this myth about whether or not there are holes in the fenders? I'm about ready just to rip 'em off and see for myself if nobody knows 100% for sure or not. Thanks for the help all!
Yes there are holes in the fenders behind the fender badges. All the rest of the badges don't have holes behind them. I replaced all my badges with a set from www.billetbadges.com
Thanks Layson. For those of you with the older bodystyle like mine, I was told (from a diff. forum) that you can repace your badges with the newer styled ones but that one pin won't line up. Have fishing line and goo gone on hand and it should work fine.
Being that they don't make newer style F-250 5.4L Triton badges I think I'll e-mail billetbadges to see how much they'd run. Otherwise I was thinking about this:
F-250 Built Ford Tough
where the "built" part would replace the 5.4L triton. Lemme know what y'all think. I'm pretty sure that the "built" part will fit fine, but I have to check sizing.
Just a quick note that is slightly off subject.. For anyone outh there with newer style badges atht are chrome and black I read in a Ford customizing book that you can take carb clean to them and remove the black to giove a full chrome look.. Just some info on badges.
yes, the 99-04 years you can use acetone to take the paint off. For the 05+ you need the carb cleaner or brake cleaner to do it....if it hasn't pealed off already.... if you know what I mean.
You can also heat up the ford badge and peal out the blue to make it chrome...
