If I replace the rear sway, should I do the front at the same time ? I drive canyons nearly everywhere I go and the limited is like a boat with all the kids and their ball gear in the back.
I also would like to reduce the brake wobble, I read the threads on that, wow, what a learning curve for all that.
rotors and slots, and pads and so many variations.
From what I've read here, rear sway is more important than front.
On the brakes - did you see the threads that talked about brake "warping". Some good external links that pointed to the problem having nothing to do with overheating, but instead bad torquing on the lugs. If you replace your pads/rotors be sure to "seat" the correctly (this was a process of warming them by repeated higher speed stops) and torque the lugs correctly - 150 to 165 foot pounds! This torquing (or not doing it) seems to be responsible for A LOT of brake woble.
Wish I could remember what thread had the link to the external write up on the "seating" process and proper torquing. Do some searches - I will also and try to post back again.
I'm curious what gain you think you'll obtain if you "replace" the rear anti-swaybar. If you already have one, leave it. Granted, bushings might need replacing if they're worn. Have you replaced the OEM shock absorbers? Most any aftermarket shock absorber is a decent improvement over stock.
no there's no rear bar right now and yes the oem shocks are still there.
maybe i should do both the bars and shocks.
it sure made a difference on my 250 when i did it a couple years back.
emptyd talked about proper bedding of the brakes, here this is out of by "break-in" document designed for new vehicles, but the process is the same for new brake pads.
Originally Posted by breakin.txt
OK, Lets BED the brakes. You should do this immediatly as you leave the dealer, in fact I do a lot of it in his lot (my dealers lot is big enough). Get up to 30mph and when safe do a very hard (not lockup or ABS starting) but very hard braking just shy of a full stop, as you feel the truck about to halt, let off and smoothly accelerate back to 25, 30 mph. Repeat this 4 or 5 times while looking for a clear parking lot or unused back road. Let about 3 or more minutes pass between hard braking series to let the rotors settle to the new temp. Do this in a place where you do NOT have to come to any complete stops with the brakes while the rotors are hot! We are deliberatly trying to get the rotors VERY hot.
Once you have a SAFE place to do some more of this, do another hard brake series and get out of it while still rolling as before, but this time just coast to a normal stop. Clear your rear and shift to reverse and get up to a fair clip and do a hard brake in reverse, but again NOT to a complete stop. Do this several times as far to the rear as you can in the selected place but try very hard to NOT bring the truck to a complete stop with the brakes pads holding the very hot rotor.
What we are doing here is "burnishing" the pads, and forcing very controlled and even heating to the rotors and attaching assemblys. There NO such thing as WARPED rotors... BUT there is a condition called material trasnsfer, caused by superheated PADs that leave some of their material on the rotor and causing them to pulsate due to the uneven surface.
For the first few days try to set up your stopping to NEVER bring you to a full stop with the pads HARD clamped to hot rotors. This is hard to do and do not ever forget safety for you and others. If you must bring the monster to a quick and complete stop as soon as you are stopped ease up on the brakes and try to creep if there is room.
That goes against everything i know about new pads and rotors. Seems this guy is trying to glaze em to get more life if anything lol. Im a fan of slow normal stops, starting from about 10 mph gradually increasing to about 45-50 with a whort cooling off period between the stops.
This guy sounds like the same guy that tells you to break in your new motor by flooring it and beating the snot out of it immediatly to seat the rings. Just seems like bad practice to me.
I can vouch for this procedure. I've done it on all three trucks. It was done the first time the Silverado was driven on the dealer's lot. The pads and rotors were original when they came out to be replaced with slotted rotors and bigger calipers at 89K. Still had life left in them.
To each his own, if you have another procedure that you believe works better, I do invite you to use it. When your brakes wear out far before mine (and Mike's!), then perhaps you'll give that method a shot.
And no, I do not believe in breaking in the engine by gunning it. That's stupid and irresponsible.
And that's why you'll be posting about {supposed} "warped" rotors here one day. I posted the original link emptyd was talking about. Warped rotors are a myth. This proper break-in procedure WILL NOT create a "glaze". That is done when you ride the brakes for so long that the material actually melts.
Avoid the mechanic that doesn't know this basic, fundamental, mechanical truth!
BTW 1, can you tell me exactly what make the rings push against the wall of the cylinder? Two choices:
I feel the bottom line on the rotor issue is no matter what you do to "break in" your pads and rotors if you are going to be heavy on the gas/diesel and then expect to stop your X like a minivan you will end up with bad rotors eventually. I ease into braking unless it is a must to jam them. This last set of rotors has treatedd me very well.
