Door Tag Questions
Old Apr 20, 2007 | 10:20 AM
turbomont's Avatar
turbomont
Door Tag Questions
Hello, I need some help. I have a 1984 F150 2WD. The axle code on the door is K. Can someone help me out and let me know what ratio that is and if it is a L.S. or not. And my spring code is BH. What does this mean.
Thank You
Old Apr 20, 2007 | 08:51 PM
Franklin2's Avatar
Franklin2
Are you sure that's correct? The axle codes I am finding are two digits, and the spring codes are 4 or 5 digits?
https://www.ford-trucks.com/article/...r_Decoder.html
Old Apr 23, 2007 | 09:42 PM
turbomont's Avatar
turbomont
From what I saw, the decoder is not for my year truck. I only saw the newer stuff. I.E. no C-6 option for transmissions.
Old Apr 23, 2007 | 10:13 PM
Franklin2's Avatar
Franklin2
Here's an old thread where someone listed the codes. The axle still has two digits.
https://www.ford-trucks.com/forums/5...ght=axle+codes
Old Apr 24, 2007 | 11:22 AM
Kylet8020's Avatar
Kylet8020
franklin i got one for ya if i dont have a door tag where could i find them codes on the truck?
Old Apr 24, 2007 | 02:28 PM
adrianspeeder's Avatar
adrianspeeder
K is the tranny code for a C6 automatic.
Go one position to the left for the axle code.
There also is a tag bolted to yer diff that has the ratio stamped on it.
Adrianspeeder
Old Apr 24, 2007 | 05:25 PM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
Codes for 1984
TRANSMISSION CODES
F-SERIES
Four speed manual A
Four speed manual overdrive B
Three speed manual C
Four speed manual F
Three speed automatic (C-6) G
Three speed automatic (C-4) J
Three speed automatic (C-6) K
Four speed manual (T19) P
Three speed automatic (C-5) W
Three speed automatic (C-6) Z
REAR AXLE CODES
F-SERIES & BRONCO
3.00:1 C2,H4,
3.07:1 31
3.08:1 H8
3.25:1 H5,
3.50:1 H6,
3.54:1 B3,C3,D3,E3,33
3.55:1 B6,H9
3.73:1 C4,E4,K6,34
4.10:1 B1,C2,D2,32,42
Old Jun 14, 2007 | 10:30 AM
kc5gxl's Avatar
kc5gxl
Howdy all from the Great Republic of Texas!
I have an 84 F150 and am trying to find the rear axle gear ratio. The tag has been removed from the hsg, and the door tag has '16' as the ratio code. In the above chart (last post) I don't see that possibility.
The engine is a 351W with a C6 trans.
I can use all the help I can get.
Thanks,
Dan Harriman 84 F150 lwb
Orange, Texas
Old Jun 14, 2007 | 10:38 AM
Mil1ion's Avatar
Mil1ion
Axle Code 16 should be a 3.50 ratio
Old Jun 14, 2007 | 10:59 AM
kc5gxl's Avatar
kc5gxl
Thank you very much!
Dan Harriman
Orange, Texas
_________________
If at first you don't succeed, maybe you shouldn't try sky-diving!
Old Jun 14, 2007 | 01:11 PM
jdgreen72's Avatar
jdgreen72
also the springs have numbers stamped in them, try that.
Old Jun 14, 2007 | 01:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Numbers on the springs are Ford engineering ID numbers, and are only found in a parts catalog.
