93 e150 won't start
Old Apr 20, 2007 | 10:20 AM
solidmetal's Avatar
solidmetal
93 e150 won't start
First, let me say Hello to everyone! I am new here.
Secondly, I did do a search, but haven't seen this particular, or I didn't search with the right terms
1993 Ford E-150 5.0L V8.
Been sitting, unused for about 2 years.
Put in brand new battery. Van powers up ok. Electrical looks good from what I can tell (radio ok, headlights ok, interior lights ok, etc.).
When I try to crank the van, nothing happens.
Starter tests good.
I do hear a single click (like a relay) when I try to crank the van, but *it is not the starter clicking*. I am not sure what it is, or if it even matters.
The problem exists between the battery and the starter.
Fuses all seem good.
Any ideas?
Old Apr 20, 2007 | 10:42 AM
subford's Avatar
subford
Sounds like a bad spade connector at the starter, try crimping a new one on.
The clicking is coming from the starter relay.
Old Apr 20, 2007 | 10:51 AM
solidmetal's Avatar
solidmetal
Could it be a dead ignition switch?
Old Apr 20, 2007 | 11:26 AM
subford's Avatar
subford
If it were working OK before it was parked I would not think that would be it.
Try cleaning the connections at both sides of the starter relay.
Old Apr 20, 2007 | 11:29 AM
solidmetal's Avatar
solidmetal
thanks for your hep so far. this definitely seems to me like a starter relay issue. Now, to show my "newbiness" .. where on a 93 e150 is the starter relay located? thanks again...
Old Apr 20, 2007 | 11:41 AM
BChance's Avatar
BChance
I my memory serves, follow the smaller diameter cable from the positive side of the battery, it should be right close to the battery somewhere on the fender well.
It will look something like this, but maybe black.
Old Apr 20, 2007 | 11:53 AM
subford's Avatar
subford
Left corner of engine compartment
Photo of your starter relay:
Old Apr 20, 2007 | 03:33 PM
quicklook2's Avatar
quicklook2
engine could be frozen up also.
Old Apr 23, 2007 | 02:25 PM
solidmetal's Avatar
solidmetal
just wanted to let everyone know it was the starter relay.
now the van tries to crank, but nothing happens.
I will start with the plugs first.
Old Apr 23, 2007 | 04:49 PM
subford's Avatar
subford
I would check for a bad ground on the small black wire with a green stripe going to G101. Left side of engine compartment, near battery, G101 is in the image above.
Krapfl
Aerostar
Feb 4, 2018 05:54 PM
tjo
May 8, 2017 01:06 PM
jimww
Nov 4, 2016 03:36 AM
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
nalts
Sep 18, 2010 07:15 AM
