Determining differential from VIN?
Old Apr 20, 2007 | 09:03 AM
tucker_bmd's Avatar
tucker_bmd
I plan on buying a used ford van. I would like to get one with limited slip differential. Is there a way to tell using the VIN? Or do I need more info? Trying to avoid emailing the same question to every van owner, the VINs are always listed.
Thanks,
Jeff
Old Apr 20, 2007 | 10:23 AM
cdrmotorsports's Avatar
cdrmotorsports
I don't think you can get it from the VIN. You need to check the sticker on the sinde of the driver door under "axle", get the code and bring it here. Someone can figure it out for you.
Old Apr 20, 2007 | 08:22 PM
Jake S's Avatar
Jake S
Under axle on the sticker, if it starts with a letter it is a limited slip. If it starts with a number, it is open.
Old Apr 20, 2007 | 11:18 PM
caseys's Avatar
caseys
..or look at the differential for any tags that are attached, the information on them will let you know.
Old Apr 22, 2007 | 11:53 AM
u2slow's Avatar
u2slow
Dealerships can look up build sheets based on the VIN. Otherwise, a picture of the GVW/VIN decal from the door jamb has a nice snapshot of info - including the axle code.
1964FordBoyertown
Oct 17, 2016 04:32 PM
Pxt808
Jan 22, 2016 08:06 AM
Oz Econoline
Apr 2, 2015 03:21 AM
I love 305's
Jan 19, 2011 09:09 AM
