1978 - 1996 Big Bronco
T-Case
Old Apr 19, 2007 | 08:47 PM
THE KING's Avatar
THE KING
T-Case
Hey, I have a clunking noise. It only happens when the truck is warm. I put it from drive to reverse or any gear and it thumps. I checked the U joints and everything was ok. I put the truck in neutral and i can move the driveshaft and hear clunking. Anyone had the same problem. tomorrow its goin in to get looked at
Old Apr 20, 2007 | 10:12 AM
Kemicalburns's Avatar
Kemicalburns
could still be ujoint,slip joint or pinnion yoke on the rear diff.
Old Apr 20, 2007 | 11:54 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Have someone turn the drive shaft back and forth, while you crawl up and down the drive line and listen to pin point where the "clunk" is coming from.
Old Apr 20, 2007 | 01:09 PM
bertha66's Avatar
bertha66
I would put the truck on jack stands and with it in neutral roll the wheels back and forth, with you under it. If you don't see anything turn the drive line by hand back and forth.
Old Apr 20, 2007 | 07:52 PM
THE KING's Avatar
THE KING
i can and it seams like its coming from the T case. My U joints are good. Could it be my yoke on the transfer case?
