I have a small ( 7 or maybe 10 gallon) air compressor that runs fine and has no leak in the tank but does not build pressure. My grandpa suggested maybe it is low on oil but I checked and it is full. It is a Speedaire and I don't know how old it is but I dug it out of a dumpster about 5 years ago and it worked fine then, just had a bent pulley. Anybody got any suggestions?
You say it has no leak in the tank so I assume it used to build pressure. Did it stop building pressure suddenly? If so, take a look at the unloader valve. Its usually located where the line from the compressor head enters the tank and its purpose is to open when the compressor reaches pressure and shuts off so that there is no pressure on the compressor head at start up. If it sticks open, all the air from the compressor is vented and none goes to the tank. They usuall cost a couple of bucks.
Most likely the valves are broken. Nine times out of ten when capacity drops off thats the reason. If you are sure there are no external air leaks, then pull the head off and inspect the valves. You may get lucky and find a piece of debris lodged under the valve. Just remove it and reassemble and see if performance improves.
fixnair]Most likely the valves are broken. Nine times out of ten when capacity drops off thats the reason. If you are sure there are no external air leaks, then pull the head off and inspect the valves. You may get lucky and find a piece of debris lodged under the valve. Just remove it and reassemble and see if performance improves.
I agree most small compressors use reed valves to build pressure and after awhile they break off and being a speedair thats most likely what happened.I have made my own from old motorcycle reeds in a pinch but you might still be able to get new ones
Reason: spelling
