428 vs. 390
Old Apr 24, 2007 | 09:23 PM
  #46
rusty70f100's Avatar
rusty70f100
Head flow, valve size, manifold differences, camming differences, etc. Like I said, all other things being equal. With two different motor families, things are never equal. Which of course, negates both of our examples.
I modeled both motors (428 and 429) in desktop dyno with equal parts (in theory, unbuildable of course) and the curves are nearly identical, with the slight advantage to the 429, by 4 hp and 1 ft-lb of torque.
It's displacement. Stroker cranks just give you more. Nothing magical about the "leverage" or anything like that.
Old Apr 24, 2007 | 10:05 PM
  #47
Ron R's Avatar
Ron R
yes its the same as a 390,
I got my 428 out of a thunderbird, It was a really cool car untill it got crashed.
Good luck real 428's are hard to find. And there is nothing wrong with a 390!
Old Apr 25, 2007 | 09:54 AM
  #48
62_Galaxie_500's Avatar
62_Galaxie_500
Hot Rod magazine did a test a couple years ago to settle the debate as to whether a longer stroke makes more torque than a larger bore/shorter stroke. IIRC the engines were within 2 ci of each other. They found that the horsepower and torque were almost exactly the same. Long story short, the old saying, "there's no replacement for cubic displacement" still holds true.
Old Apr 25, 2007 | 11:33 AM
  #49
"Beemer Nut"'s Avatar
"Beemer Nut"
Look at the torque numbers of Olds and Chrysler motors in the 60's with big bores short strokes, high numbers at fairly low rpm's but they had high compression and good fuel back then. Today we have to make torque with crappy fuel.
Anytime someone mentions a 4x4 that's heavy, operates at low rpm's for off road or a truck loaded for towing I recommend a 410 or 428 build with the proper cam and equipment.
If there's such a thing as having too much torque let me know plus use less throttle.
Old Apr 26, 2007 | 10:56 PM
  #50
scottfreeman's Avatar
scottfreeman
So, are the 360 rods shorter than the 390 rods? Or is the crank stroke the only difference?
Old Apr 26, 2007 | 11:12 PM
  #51
rusty70f100
360 rods are longer. There were two length rods used on FE's and FT's. A short rod, and a long rod.
Short rod = 6.488"
Long rod = 6.54"
Long rod was used on 332, 352, 360, and some 330's.
Short rod was used on everything else.
Old Apr 27, 2007 | 10:41 PM
  #52
TG28's Avatar
TG28
i just discovered a 68 cougar a couple miles from my house for sale with an old 8n tractor , what are the odds it has a 428. i am going to see if i can catch the owner at home tomorrow!
Old Apr 27, 2007 | 10:52 PM
  #53
Ron R's Avatar
Ron R
Slim to none with the 428 in it.
And if it has the 428 its worth a few $$.
Old Apr 27, 2007 | 10:56 PM
  #54
Ron R's Avatar
Ron R
look for a fairlane wagon, I got mine out of a crashed thunderbird.
Also (hind site for me) check with your local machine shop. The one by me in Everett WA. has two 428's with cranks and rods sitting on the shop floor. Ready to re-build. Lots of people have big dreams and no $$ to pay the machinest when there block/crank are done. Also Craigs-list has a lot of stuff on it. Or just pony up and get an aftermarket block/crank/rods/heads!!
Old Apr 28, 2007 | 07:27 AM
  #55
baddad457's Avatar
baddad457
Hope you weren't thinking about the 455 Olds here. Nothing short about it's stroke (4.125") But at nearly 500 ft lbs for the lowly 2 bbl 455 ( that tiny Rochester carb looked so out of place there) it was a torque monster. My Moms 70 Delta 88 4 dr hardtop would smoke em on demand.
Old Apr 28, 2007 | 12:38 PM
  #56
"Beemer Nut"
No on the 455 as they did have a long arm, I was speaking about 383's and the likes.
Old Apr 30, 2007 | 08:25 PM
  #57
scottfreeman
So, can you run the 360 rods w the 390 crank with some pistons w the pin off set just right?
Old Apr 30, 2007 | 08:31 PM
  #58
baddad457's Avatar
baddad457
Why would you want to? The 352/360 rods are visibly weaker. Just compare the two side by side, you'lll see what I mean. The miniscule difference in length isn't enough to justify that over the strength loss.
Old Apr 30, 2007 | 09:23 PM
  #59
"Beemer Nut"
Maybe a ventilated block is cheaper than the proper set of rods?
Old Apr 30, 2007 | 11:19 PM
  #60
scottfreeman
Just wondering, I have access to a 390 crank but not rods.
