Axle ?
Old Apr 19, 2007 | 09:20 AM
tcervi1028's Avatar
tcervi1028
Axle ?
Does the oil in the center section also lube the wheel bearings? Looking in my repair manual it states in there that you should pack the wheel bearings befor assembly? I have never done this w/the old dana 60 axles. Thanks Tony
Old Apr 19, 2007 | 09:24 AM
mech2161's Avatar
mech2161
On the rear axle the diff fluid does lube the bearings. Just use the same oil to coat the bearings before instalation.
Old Apr 19, 2007 | 01:55 PM
John311t's Avatar
John311t
Are you talking about the front axle or the rear axle? Front axle is a dana 60, the rear is a ford sterling 10.5 if SRW and a dana 80(could be wrong on number but i know dana) if drw.
Old Apr 19, 2007 | 04:48 PM
tcervi1028's Avatar
tcervi1028
Its the sterling 10.5.I just spent the hole day taking it apart,cleaning,and inspecting.Replaced a couple seals.The question I have now is this stuf your supposed to add to the oil for the limited slip,Can I drive it at all with out it? Its late cant get to the dealer today,got to be at work 4am tomarrow need to use the truck..
Old Apr 19, 2007 | 09:01 PM
cangim's Avatar
cangim
Yeah you can drive it as is. It will just have more limit to it than without the friction modifier.
