help locating
Old Apr 19, 2007 | 02:15 AM
donaldm's Avatar
donaldm
help locating
01 ranger 3.0 Which relay is the fuel pump relay? I dont have a owners mauel which shows which is fuel pump relay. I know its under the hood in the black box "fuse compartment" inside the lid theres lables with numbers but anybody know which is the fuel pump relay.
I ran out of fuel and im going to try using a jumper to run the pump to prime the line. thanks
Old Apr 19, 2007 | 08:44 AM
RangerPilot's Avatar
RangerPilot
No reason to do that just to prime the line. Turn the key to run but don't start the truck. Do it two or three times, you'll hear the pump run every time you do it (it runs for two seconds when the key is turned to run to prime the fuel system).
