Rear Heater Core??
Old Apr 18, 2007 | 09:49 PM
sparksalot's Avatar
sparksalot
Rear Heater Core??
Have a 2000 Expedition that seems to be experiencing a rear heater core problem. Started out sounding like a gurgle in the left rear panel where the auxilliary blower and heater core are located. The gurgling stopped and now I have a constant click...click...click. Sounds like maybe a solenoid or a valve is sticking. Also have no heat in the rear when controlled by the front or rear controls. I believe that the no heat is caused by the heater core, but is it not working because the core truly is bad or because of a faulty solenoid or switch or valve and how might I be able to troubleshoot this??? Help, please. Thank you.
Old Apr 19, 2007 | 04:48 PM
FTE Herman's Avatar
FTE Herman
Oh man, I don't know. Is there any way you can open it up and see if the lines are hot and/or if there is some type of heater control valve that is not opening?
Old Apr 20, 2007 | 07:05 AM
sparksalot's Avatar
sparksalot
Well, I have not checked any of the lines yet for a valve. BUT I did locate some posts in here that related to the blend door. With the info I found here I was able to determine what was actually making the clicking noise. There are two small kind of clear or opaque units that seem to be actuators or little motors. I think have something to do with the blend door. Anyway, I determined which one was making the noise. I opened the little box up and found that one of the smaller gears had almost all of the teeth broken off it. So I'm gonna get it replaced and see if this fixes my heat and noise problem.
Old Apr 20, 2007 | 10:02 AM
tatetodd's Avatar
tatetodd
sparks you hit the nail on the head. That will solve the problem and is only about $50 as I recall. The clicking is a dead giveaway!
Tip for replacement if doing it yourself (keep the old unit take off the shaft and use it to help guide you with aligning the new one)---also can get someone else to slowly move the rear temp controller until the actuator shaft will go into place.
good detective work. I had no idea until the FTE guys told me what the problem was.
Old Apr 20, 2007 | 01:16 PM
sparksalot's Avatar
sparksalot
No probem. Found part at Napa for about $49 plus shipping and tax. Thanks everybody.
Old Apr 20, 2007 | 02:02 PM
sparksalot's Avatar
sparksalot
Oh, and BTW I took out the interior for ease of removal and reinstallation.
jasonodsky
Sep 8, 2020 05:19 PM
ExBeast
Jul 13, 2016 04:24 PM
tabijan
Jun 23, 2014 06:31 AM
BURNSTOUGHFORD
Nov 24, 2009 02:05 AM
khilding
1978 - 1996 Big Bronco
15
Nov 26, 2008 11:39 PM
