Coolant temp on 460
Old Apr 18, 2007 | 09:11 PM
mean green2's Avatar
mean green2
Coolant temp on 460
Does anybody happen to no the ford recomendations for the coolant temp on a 460?
Old Apr 18, 2007 | 09:23 PM
BChance's Avatar
BChance
Factory Ford manual recommends a "high temp" thermostat (195) for factory coolant which they consider "permenant" and a low temp (160-180) for "non-permenant" coolant, both at a 50 50 blend, a-freeze/water. They came out of the factory with a 195.
I always avoid the 160 thermostats since some computer functions can be affected if the engine doesn't get warm enough. I run a 180 in mine with no problems.
Old Apr 18, 2007 | 11:02 PM
mean green2
I have a 180 thermostat in mine, well ive redone the whole cooling system, and on avg its now running 180degrees to 210 degress, but normally it was 200-220 before i changed out the coolant again.... Jw was what was considered normal because of the factory guage,
