1978 - 1996 Big Bronco
Power Window
Old Nov 4, 2001 | 12:50 PM
Julio's Avatar
Julio
Power Window
My drivers side power window (88 Bronco) is stopped a couple of inches up from the bottom and the motor seems dead. I've taken the inner panel off and think I've located the rivets that need to be drilled to remove the motor. However I can't pull the window up. Also, how and when do I disconnect the motor from the lift arm and am I doing this correctly? Any help would be appreciated.
Old Nov 4, 2001 | 09:00 PM
Julio's Avatar
Julio
Power Window
