Starting The Upgrade
Old Apr 18, 2007 | 05:38 PM
suicide29's Avatar
suicide29
ok, here's what I've decided upon for the X suspension upgrade, let me know what you all think!!!! Hellwig rear stabilizer rancho9000 shocks rough country dual steering stabilizer new ball joints and front end alignment.
Old Apr 18, 2007 | 06:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
Can we ASSume that you currently have a stock 4x4?
Old Apr 18, 2007 | 06:49 PM
suicide29's Avatar
suicide29
yes sir that is correct. I have a 2000 limited 4x4 with 83000 miles 3000 of which I have put on it
Old Apr 19, 2007 | 12:39 AM
RACERX7775's Avatar
RACERX7775
i did 4 billsteins, rear hellwig, new wheels and tires, rough country dual inline steering stabalizer, and front sway bar bushings and links, front and rear rotors and pads. wow, what a diff. now i need to do the manual hub conversion. ball joints to follow that too.
Old Apr 19, 2007 | 11:31 AM
Mike Kopstain's Avatar
Mike Kopstain
I have the Bilsteins and hellwig as well. Big difference but it's still knocking over everything.
Get those balljoints replaced guys. I just popped my truck up and mine are toast. Same goes with the springs which are apparently a wear item on the Excursion.
Old Apr 19, 2007 | 01:14 PM
njstevens's Avatar
njstevens
Springs and ball joints are lazy employees on your truck. They never want to work that long for you. Suicide it looks like you are going all out. Good luck with it . It will change the way your truck drives and rides. Also get driving that beast. She has no miles on her for a 2000. lol
Old Apr 19, 2007 | 02:03 PM
suicide29's Avatar
suicide29
I most certainly plan on adding to that mileage total I'm just glad the guy that owned it before me took such good care of her and left me with lots of miles to go!!!!! you guys all seem to have gone with the bilsteins are they a better recommendation than the ranchos? SPRINGS? I need new springs too??? which ones do you recommend
Old Apr 19, 2007 | 09:35 PM
RACERX7775's Avatar
RACERX7775
i did the v spring in the front and in the rear i did the f350 block. still need to do balljoints and front warn hubs.
