batchfire speed density to sequental speed density
Old Apr 18, 2007 | 02:15 PM
oreodog's Avatar
oreodog
How do i do this? Any links out there?
There are kits out there to change from speed density to MAF by repinning a few wires in harness and using maf computer.WHY CANT I CHANGE MY 302 IN MY 1987 TRUCK TO WHAT THE MUSTANG COMPUTER USES!!
IM swapping a mustang 302HO into my truck and have the factory mustang HO ECU but not its harness.THERE has to be a easy way to add a extra O2 sensor and wire the 8 injectors in sequential order! Any help?
Old Apr 18, 2007 | 10:35 PM
Franklin2's Avatar
Franklin2
There is two ways I can think of, but none are easy.
1. Get a mustang harness and install it.
2. Get a mustang wiring diagram, and a truck wiring diagram, and make the necessary wiring changes yourself.
I have to ask, what is the reasoning behind doing this? The mustang motor would drop in if you used the truck stuff. The extra horsepower the mustang engine had will do little good in a large heavy truck. You need torque, which is what the truck efi system was designed for.
