Max Tire Sizes
Old Apr 18, 2007 | 11:25 AM
MisterCMK's Avatar
MisterCMK
Max Tire Sizes
I grabbed this from the other Explorer site. I figured that it would be helpful for a number of users here.
Originally Posted by The Other Explorer Site
Lifts and max tire and wheel sizes for explorers
This is a quick reference guide I have put together based on information gathered from the Explorer Forum. Remember this is just a guide. You may have to do some fender trimming to fit these tires on your explorer. Others things can change what size tire you can run on your explorer. Like fiberglass fenders, rim width and rim backspacing.. I figured this would help some of you that were pondering what size lift to run what size tires.If anyone would like to add something go ahead and post it and I will add it to my list. If any of the moderators could make this a sticky that would be great. Hope this helps.
For Metric Users: Click here to convert Standard to Metric and vise versa.
91-94 explorers.
No lift- 31x10.50x15 on 15x8 inch rims
1-2 inch suspension lift- 31x10.50x15 - 32x11.50x15 on 15x8 rims/ may require some extensive fender trimming
2-3 inch suspension lift- 32x11.50x15 on 15x8 rims
3-4 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rims/ may require fender trimming
4-6 inch suspension lift- 33x12.50x15 - 35x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift- 32x11.50x15 on 15x8 rims/ may require fender trimming
3 inch body lift- 33x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 2-3 inch suspension lift- 33x12.50x15 on 15x8 inch rim
2 inch body lift and 4-6 inch suspension lift – 35x12.50x15 – 36x12.50x15 on 15x 8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 2-3 inch Suspension Lift – 33x12.50x15 – 35x12.50x15 on 15x8 rim
3 inch body lift and 4-6 inch Suspension lift – 35x12.50x15 – 36x12.50x15 on 15x8 inch rim
6 inch Suspension Lift - 36x12.50 on 15x7 factory wheels (requires fender trimming, firewall clearancing and rocker panel modification)
6 inch Suspension Lift - 35x14.50 on 15x8 wheels with 4" back spacing (requires fender trimming, firewall clearancing and rocker panel modification)
95-2001
No lift- 31x10.50x15 on 15x8 rim
1-2 inch suspension lift - 32x11.50x15 on 15x8 rim/ may require some extensive fender trimming
4 inch suspension – 33x12.50x15 on 15x8 rim
2 inch body lift – 32x11.50x15 on 15x8 rim
3 inch body lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 4 inch suspension lift - 33x12.50x15 – 35x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 4 inch suspension lift – 33x12.50x15 – 35.12.50x15 on 15x8 rim/ may require fender trimming.
You may be able to run 33x10.50x15s inplace of 32x11.50x15s
2002-2005 Ford Explorers
No Lift - 32x10.50 or equivelent in Metric Measurements on Stock Wheels (265/75/R16 or 265/70/R17) - no modification needed!
deano-was-his-name-o
Feb 22, 2016 12:37 PM
coachnichols
1978 - 1996 Big Bronco
Feb 5, 2016 10:43 AM
87wreckerman
Nov 16, 2015 12:00 PM
Something Cool Here
Aug 28, 2015 08:11 AM
rebocardo
Oct 7, 2002 02:13 AM
