Sponsored by: Real Truck
removing trim - moulding
Old Apr 18, 2007 | 06:32 AM
worknon10s's Avatar
worknon10s
I want the clean look for my 2000 f250. How do you remove the door trim and get the stisky tape off without hurting the paint.
Thank you
Old Apr 18, 2007 | 06:38 AM
PHWLEE's Avatar
PHWLEE
I've heard that WD-40 can be used to remove the sticky stuff and won't harm the paint. I've tried it myself and it does seem to work. Not too sure about the trim itself other than carefully getting a grip and then slowly pulling it off. It won't be too easy though. That double sided tape is pretty strong stuff. Maybe someone else here might have a better approach.
Old Apr 18, 2007 | 07:13 AM
mel2000f150's Avatar
mel2000f150
Avon has some stuff called "SKIN SO SOFT", I use it all the time to get the goo off.
Heat the trim up first to help remove it.
Old Apr 18, 2007 | 07:25 AM
350z's Avatar
350z
I've always used fishing line,to cut through the tape ,hold the line between your fingers pulling towards the back of the molding moving back and forth like your sawing through it , it works great , as said above W-40 and a hair dryer or heat gun(if used carefully) using your fingers only , (any type of scraper will probably end up in disaster) will help get the tape off , Craig.
Old Apr 19, 2007 | 03:47 AM
04F-250 stroked's Avatar
04F-250 stroked
heat it up with a heat gun pull very slowly most will come right off. try zippo lighter fluid to remove left over tape and glue... thats what my detailer uses
Old Apr 19, 2007 | 05:30 AM
eysham's Avatar
eysham
how about a 4.5" angle rotary disc...?????... just don't forget to heat up with a CO2 burner before...
just kidding.
as said before, use WD40 works like a charm
eysham
Old Apr 20, 2007 | 07:07 PM
getnbz's Avatar
getnbz
i use either GOO GONE i got at walmart or a heat gun or Stoner XENIT they all work good
Old Apr 20, 2007 | 10:45 PM
mcjones44us's Avatar
mcjones44us
All these are good suggestions. I had a limited excursion with the lower body cladding and I ended up taking it off to get that "clean look". All kinds of tape behind those panels.
I found that heat helps more than anything else, goo gone helps too. I also found the best removal technique was to sort of "roll" the tape goo off with my thumb while wearing gloves; much better than picking at it.
Old Apr 21, 2007 | 07:23 AM
getnbz's Avatar
getnbz
definatly wear gloves skin get raw rubbing glue off
