temperature gauge wacky!!
Old Apr 17, 2007 | 09:43 PM
PICCALO358's Avatar
PICCALO358
f100-1980-l6-300-2wd auto-pb-ps--temperature gauge,fuel,oil gauges all go higher than actual and then go normal for while. Have changed voltage regulator in dash. Any suggestions on this problem.
Old Apr 17, 2007 | 10:04 PM
Piffery1's Avatar
Piffery1
Poor instrument panel ground can cause this. I added a separate ground from the Instrument Voltage Regulator mounting tab directly to the dashboard metal frame. All the IP grounds go through one connector pin. Might help dim or flickering IP lamps.
