bumper question
Old Apr 17, 2007 | 04:56 PM
bsecrease's Avatar
bsecrease
Question bumper question
will the front bumper off of a 1996 f150 fit on a 1990 f150?
Old Apr 17, 2007 | 05:05 PM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
it might look wierd since the 96 front end is a little more rounded than a 90
Old Apr 17, 2007 | 05:08 PM
bsecrease's Avatar
bsecrease
Question
so it will fit? are the bumper mounts the same? or will i have to fab new ones?
Old Apr 17, 2007 | 05:10 PM
Josh88Ford's Avatar
Josh88Ford
no, the 92-96 have different mounting brackets, and a crumple zone. Some mods will have to be made. there is a little bit more steel on the sides, that follow the wheel well line. Usually people cut this so bigger tires dont rub
Old Apr 17, 2007 | 05:14 PM
bsecrease's Avatar
bsecrease
Question
ok i was wondering, cause i have a couple different bumper options. a bumper from a 96, and a bumper from a 89... now are the mounts from the 89 to a 90 the same? i would think they would be....
Old Apr 17, 2007 | 06:03 PM
Autoglass's Avatar
Autoglass
The bumper from the 89 is a flat style vs. a rounded style!
AND THEY WILL NOT INTERCHANGE!
Old Apr 17, 2007 | 06:43 PM
bsecrease's Avatar
bsecrease
so a bumper from a 89 f150 will not fit on a 1990 f150?
Old Apr 17, 2007 | 07:46 PM
lostin90s's Avatar
lostin90s
yes any bumper from 87 to 92 body change should fit with no problem. The newer biumper is rounded as said and unless you cut at wheel well the center sicks out a ways . good luck on switch
Old Apr 17, 2007 | 08:21 PM
bsecrease's Avatar
bsecrease
thanks for the help. hopefully the bumper will go on with out a hitch.
mrl390's Avatar
mrl390
87-91 bumpers interchange and 92-96 bumpers interchange. Body style changed in 92.
texasman
Nov 12, 2013 11:11 AM
jmikeyj4
Sep 14, 2013 09:26 AM
gradynh
2009 - 2014 F150
Oct 16, 2009 11:21 AM
DavidB
Aug 15, 2002 03:52 PM
