timing chain deflection
Old Apr 16, 2007 | 10:44 PM
Sandman1991's Avatar
Sandman1991
what is the maximium timing chain deflection for a 94 f 150 with a 5.0L?
Old Apr 17, 2007 | 05:32 AM
HemiEater's Avatar
HemiEater
well,........none i guess...........explain
Old Apr 17, 2007 | 06:44 AM
EPNCSU2006's Avatar
EPNCSU2006
I think 1/2 inch on the slack side, assuming you have the timing cover taken off already. If not, turn the engine in one direction until you reach the TDC mark, then pop off the distributor cap and watch the rotor as you turn the engine the opposite direction. As soon as you see the rotor start to turn, stop turning the engine and make note of how many degrees the crankshaft was turned. The limit is 4 or 5 degrees.
Old Apr 17, 2007 | 05:22 PM
Sandman1991
it has just over a half inch. i checked the price of a new one its only 55 bucks just gonna change it anyway
Old Apr 17, 2007 | 08:17 PM
Drizzt's Avatar
Drizzt
just change it tyler you cheap *******
Old Apr 17, 2007 | 11:35 PM
Sandman1991
thanks for stating what i already said glen you
Old Apr 18, 2007 | 06:37 AM
Drizzt's Avatar
Drizzt
i <3 you
