Cleaning your engine/Engine Compartment
Old Apr 16, 2007 | 06:02 PM
parcours's Avatar
parcours
What do you guys use to clean your engine?
I had some service done on my '06 F250 and they did a great a job cleaning the engine.
Is a high pressure washer OK to use?
Old Apr 16, 2007 | 07:17 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
No it pushes water into places you dont want water ie air filter...
Old Apr 16, 2007 | 07:33 PM
slowmans's Avatar
slowmans
i used this purple cleaner i got at home depot, i think it was called purple stuff? i wouldn't use simple green it pretty rough on aluminum.... just a light spray of the hose and it looked brand new!
Old Apr 16, 2007 | 08:40 PM
BowTieHatr's Avatar
BowTieHatr
pressure washer will not hurt anything if you dont spray direct onto anything. seals are everywhere important, so nothing to worry about.
Old Apr 17, 2007 | 09:34 AM
RJB1's Avatar
RJB1
I just use the high pressure at the car wash after letting the engine cleaner soak. It works great.
Old Apr 17, 2007 | 11:56 AM
msgtg's Avatar
msgtg
Any detail techs out there....
If anyone would know, they would.
Old Apr 18, 2007 | 09:18 AM
sgthawkusmc's Avatar
sgthawkusmc
I wouldn't even consider a pressure washer. I've had too many issues with too many vehicles with them. The second time after having problems doing it the year before I said I'll just do it a little more gently. Same kind of issues. Tried it on other cars with the same bad results. It's not worth it. Three strikes and the pressure washer is out for me.... Use a degreaser and if you have to a light spray with the garden hose. I can't imagine the seals are that much better on the 6.0 over some of my other vehicles.
Old Apr 18, 2007 | 02:15 PM
wiingnut's Avatar
wiingnut
just say no to pressure washers, before it's too late
Old Apr 18, 2007 | 02:58 PM
Reidicus's Avatar
Reidicus
I pressure washed my engine a few times. DO it when the engine is still cold.
Old Apr 18, 2007 | 06:30 PM
WishIhada7.3's Avatar
WishIhada7.3
6.0 diesel doesnt have a Distrib to get wet or short out the contact...if u know what can be washed and dont hammer on anything it wont hurt...been doin it for many many years. had more issues with so called degreaser chemicals to clean a engine than a pressure washer...
