Towing V8 Gas VS V10 Gas 3.73 Axle ratio VS 4.10 Axle ratio
I am looking at buying a 2008 F250 but am confused on engines and axle ratio's.
I will be towing a 5th wheel camper.
What will be the best as far as towing and espescially gas mileage these days, a V8 with 4.10 Axle Ration which I guess will tow 11,800 pounds or a V10 with a 4.10 Axle ratio which will pull 14,700.
I will be towing a max of 10,800 pounds fully loaded trailer.
If I get the over kill on the engine will my mileage be as good or better than the V8, is it worth the extra bigger engine?
Go V10 and 4.30. V8 is too small and will get worse mileage than V10 while towing. You will be stomping on the go pedal all the time.
I have 3.73's and with bigger tires it's more like 3.58's. I wish I had 4.30's. You may lose 1mpg while driving empty, but the truck will be livelier than with the 4.11's It certainly will tow better.
Have you been able to FIND a V10 on the lot?
Go with the 4.30s and the V10 I had a 5.8 with 4.10s and when I got my new truck it was night and different pulling it was like a 300 six to my V10. The new 3 valve motor and tranny and towcommand the brake control are very great to tow with Ford has a good system. Go with it.The $600.00 option is well worth it.
