Sponsored by: Real Truck
Steering Wheel Oscillation 05 Sd
Old Apr 16, 2007 | 12:14 PM
WCMOTORSPORTS's Avatar
WCMOTORSPORTS
I have a 2 customers with SD an 05 and an 06 both are 6.0L. One truck has a 8" Fabtech with 2.5" coil spacers and the other has a 8" Fabtech They are both four link suspension kits and both have 3 steering stabalizers. I have already performed TSB 06-015-1. I have also replaced the track bar ball joints, dropped the tracked bar braket down an additional 3" and made new adjustable track bars.
Old Apr 16, 2007 | 12:17 PM
WCMOTORSPORTS
Sorry the both trucks have really bad steering Oscillation @ highway speeds. The steering will shake uncontrolably untill you slow down under 45 mph. I have already talked with Fabtech about this problem.
Old Apr 16, 2007 | 12:33 PM
miker67's Avatar
miker67
Out of balance tires?
Old Apr 16, 2007 | 03:20 PM
flatfnder's Avatar
flatfnder
Did the trucks have the shake before the lift was installed?
Old Apr 21, 2007 | 03:49 PM
arl8733's Avatar
arl8733
4wd Low
I just had a vibration fixed that I thought was front end and it turned out to be a drive shaft that was out of alignment. Had to shim the bracket.
Old Apr 21, 2007 | 04:17 PM
arcatek's Avatar
arcatek
well my truck does that but only when im slowing down from 60 mph and only until about 35 mph or so i dont know what its from i rotated my tires and then it started but i dont think the tires are out of ballance but you think that could be the problem?
Old Apr 21, 2007 | 09:14 PM
arl8733's Avatar
arl8733
4wd Low
Sounded strange to me too. I had the tires rotated and balanced with no change. Steering wheel would shimmy anywhere from 55 mph up. That fixed mine. It wasn't just in slowing down like yours though.
Old Apr 23, 2007 | 08:47 AM
WCMOTORSPORTS
This problem started 20k after lift was installed. It is not a tire balance issue, it is a vibration over 60 after hitting a bump or going over an over pass. This is a Ford problem not a lift problem.
Old Apr 23, 2007 | 10:35 AM
msgtg's Avatar
msgtg
I'm not sure it IS a Ford problem....STANDARD DISCLAIMER: I'm not a mechanic...I'm a truck owner and shade tree mechanic.
Any time you start modifiing the suspension....you're creating the potential for problems. According to the post, everything is good until you hit a bump or an overpass. Just one guys opinion, but I would point to the lift kits.
krewat's Avatar
krewat
FTE Leadership Emeritus
It is my honest opinion you will find that the steering boxes are to blame.
The spool valve springs aren't strong enough to keep the rebound from getting the steering box into a resonation that won't quit.
I heard from one guy who went back to the dealer 3 times or more, they kept changing the box until finally found one that didn't do it.
You might want to adjust the lash in the box first.
Also, have you tried a steering stabilizer (or two)? I know, many consider it a band-aid, but it would be interesting to know if it helped at all.
Old Apr 23, 2007 | 11:43 AM
WCMOTORSPORTS
Stock trucks have this same problem. This is a prblem that Ford knows about becouse there is a TSB for it!
Old Aug 11, 2007 | 09:42 PM
phi214's Avatar
phi214
It's not a lift problem. I had the same problem with a stock truck. I have a 2005 f350 4x4 dually. What you are talking about is the death shake. I had this problem and everyone was scrathcing their heads. Ford can kiss my butt on this one. I have always been into suspension and sat down and took some measurements and studied the suspesion and steering on the front end. I came up with a bad geometry problem with the factory stabilizer. The location it is installed causes it to do the opposit of what it is there for. being so close to the steering box causes bumps in the road to be able to manipulate the steering very easily. If you want to fix this buy a dual steering stabilizer and put in on the truck. Buy one that bolts onto the axle and attaches to the steering linkage between the front wheels. You will notice a difference. I promise. Ford needs to go back to the drawing board on this one. Forget all the crap about checking your tires, shimming the steering linkage, or the replacing your steering wheel. The best kit I have found for this is the fabtech dual stabilizer kit. Hope this helps you man.
Old Aug 11, 2007 | 10:43 PM
krewat's Avatar
krewat
phi214, WELCOME to FTE!
I never realized the steering stabilizer was close to the steering box on the 05-up. That would explain a lot of things.
Old Aug 11, 2007 | 10:50 PM
phi214's Avatar
phi214
On alot of the late models the stabilizer mount is located at the linkage close to the pitman arm. Way to close. On some of the early model superduty's 99-03 and the occasioanl few late models the stabilizer is mounter between the lower linkage and the axle. Not too many of those had the bad shake if any.
Old Aug 18, 2007 | 09:14 AM
WCMOTORSPORTS
I have made a fix for the problem. I should be able to start mkaing the parts in a couple of weeks .
