Demonstrating the proper use of a PSD.
Purty
Just cause its purty dosent mean anything. I like the look of the chevs, but man do what our trucks can do and still look as classy and thats a truck. Any truck can be set up in a car show sitting in its spot just looking pretty, but see one of those trucks going down the road with a load and that sound of a disesl at work. Thats what life is all about!!!
I recently replaced the drivers side rear cab mount in my 95 crew cab. It wasn't that bad. I was able to access the top bolt by sliding the rear seat forward. The lower bolt looked hard to find but all I had to do was take off the front tank strap and loosen the back one. The tank pushed right out of the way. I then jacked up the cab and it slid right in. Some people need to loosen the drivers side rear cab mount but access is easier on that side. The whole process took about 1.5 hours.
P.S. An impact helps alot when working alone
