Problems Again!!!
Old Apr 15, 2007 | 09:25 PM
jboard's Avatar
jboard
Exclamation Problems Again!!!
Im having the same problems again go to start the truck and the check engine light comes on doesnt happen all the time but does often. Then i get the OD flashing light and early shifts or TC locked shifts/hard shifts. I replaced the VSS, ICP sensor recently...and within the last 4 mos i replaced the TPS pedal assembly, and CPS. I have noticed someting though if the light comes on when i turn the key to run I can push the pedal a little and the light goes out let off and the light comes back on sometimes. Its weird...also sometimes i let off the gas and the light comes on while driving and all the shifting wierd comes back. Im gunna take a look at the TPS and see if someting is stuck in it or something because i do know if the TPS is pushed in a little without the IVS being released it will set a CEL so ill check that out tomorrow. Any ideas???
Old Apr 16, 2007 | 12:56 AM
ForemanES's Avatar
ForemanES
What codes can you pull from your superchips programmer?
Old Apr 16, 2007 | 07:51 AM
bkcowboss's Avatar
bkcowboss
I am not a auto trans guy , but I think you are on the right track, I would put my money on a sticky idle validation switch, it can cause havoc if it is slow to release.
Old Apr 16, 2007 | 07:52 AM
bkcowboss's Avatar
bkcowboss
saw in another post to try and free it up with wd 40 I would be careful about soaking it to much though lots of electronic stuff in there
Old Apr 16, 2007 | 10:15 AM
jboard's Avatar
jboard
Yea thats what im gunna try I think that may be the problem no codes on the programmer tried that just before i boxed it up and shipped it out to someone who bought it on ebay...lol savin up for a real chip now.
----------Jeremy
Old Apr 16, 2007 | 02:29 PM
glasseater's Avatar
glasseater
yeah try the wd40 thing probably is the tps
1r1d1um
49
Mar 7, 2023 05:56 PM
6.9idiatsturbo
18
Aug 15, 2016 05:54 PM
ResJudicata
Jan 7, 2016 09:52 AM
fordman19762003
Jul 1, 2015 05:00 AM
eakanator
Jun 4, 2002 07:03 AM
