Sponsored by: Real Truck
Squeaky Rear Window
Old Apr 15, 2007 | 01:09 PM
nut1605's Avatar
nut1605
Squeaky Rear Window
I have a 2007 F350 CC with the manual sliding rear window. I have noticed whenever I go over speed bumps, or uneven roads, or anything like that, the rear window squeaks near the slider. Anybody had this problem before? If so, how do you fix it? Thanks!
Old Apr 15, 2007 | 10:38 PM
ReAX's Avatar
ReAX
You probably need to lube up the channel and seals. Mothers preserves would serve you well, but silicone lube will do just as well in the track.
Old Apr 16, 2007 | 12:06 PM
nut1605's Avatar
nut1605
ReAX - Thanks for the tip. I never thought of something like that, so I will give it a shot!
Old Apr 16, 2007 | 07:14 PM
PHWLEE's Avatar
PHWLEE
Don't forget that with a brand new truck like that, it should be under warranty if the shot of lube doesn't do the job.
Old Apr 16, 2007 | 07:24 PM
ReAX's Avatar
ReAX
I understand a new truck shouldn't make annoying noises, but would you really expect a dealership to replace the window because it squeaks?
Old Apr 16, 2007 | 07:50 PM
PHWLEE's Avatar
PHWLEE
True. I am sure they would probably just give it a shot of luber too. My truck developed a kind of squeaking from what sounds like the weatherstripping around the doors. I am going to try and pull back the carpeting when the weather gets nice and maybe try torquing down the cab bolts. Pretty annoying the squeaking. And the lube hasn't helped.
Old Apr 16, 2007 | 08:06 PM
ReAX's Avatar
ReAX
You need to try a thicker lube. Next up from silicone would be white lithum or graphite. After that you start getting into grease.
Old Apr 17, 2007 | 03:04 PM
PHWLEE's Avatar
PHWLEE
I can give those a try. I would think that the petroleum based products will attract and hold dirt though. Might be a bit messy after a little while.
Old Apr 17, 2007 | 04:20 PM
ReAX's Avatar
ReAX
Well, Energy Suspension makes a silicone assembly lube that is as thick as bearing grease and not quite as messy. You may try to find a couple ounces of that.
Old Apr 17, 2007 | 06:15 PM
PHWLEE's Avatar
PHWLEE
Thanks, I'll look for that and give it a try. I went out this afternoon and adjusted the door a little and the squeaking is way down. I think the door was too tight against the weatherstripping and everytime the cab flexed it caused the rubbing.
