351n head issue
Old Apr 15, 2007 | 09:43 AM
JBradley500's Avatar
JBradley500
Question 351n head issue
I was wondering if anyone had experience with these 351n heads. My cousin has a SVO block, dual plane intake, flowed 750 holley, solid flat tappet custom cam with 500+hp in his circle track car, and it seems to run very well with one exception. If its not up to temp. it will pop pretty bad when its on the throttle, and if he runs it around the track a couple of times it will eventually run normally. We talked to the engine builder and he said that he believes the heads are so efficient that it is causing the popping until there is some fuel left over in the combustion chamber. This is the second engine these heads have been on and its the same situation.
Is this a normal condition or is there a problem with something in the heads/other parts??
Old Apr 15, 2007 | 10:46 AM
baddad457's Avatar
baddad457
Sounds to me like he needs to spend time jetting the carb.
93 mix 'n match
Apr 24, 2011 10:56 PM
matpasch
Jun 2, 2010 01:49 PM
89_Brnko2!!
Bronco II
19
Feb 20, 2009 09:43 AM
JBradley500
Nov 30, 2007 09:36 AM
hellraiser
Feb 5, 2003 06:49 PM
