built 1/25/03--in service 2/11/03-
12/12/03--27004--bad power mirror switch
9/27/04--35476--heat shiled rattle,cut rotors for pulsation
3:73 open rear diff.
that's all---
2/21/05 build date--8/18/05 in service
all repairs at 1 dealer
9/27/05-3353-reprogram pcm for trans concern
10/19/05--4423-machine frt rotors
2/11/05--5930-r&r valve body trans-re-align frt end
1/4/06--10346-fuel filter cap leaking
1/24/06--11598-05e16,05b32 recalls
5/30/06--20061-machine rotors replaced pads
7/31/06--24866-both 1/4 glass motors,all 4 shocks leaking?,steering wheel switches for radio
10/10/06--29864-r&r engine for multiple oil leaks,replaced frt rotors,clean egr valve-carbon
11/21/06--31842-exterior temp display concern,check engine light-no repairs
11/24/06--31930 check engine light no repairs
different dealer
2/6/07--34598-rav inspection,2nd row center seat belt retractor,rear door check brackets,replaced turbo,egr cooler,fuel filter,t-stat,fuel pressure regulator,realign frt end.
