Whats all this mean?
Old Apr 14, 2007 | 02:56 AM
SDTruckMan's Avatar
SDTruckMan
Help me understand what all this is...
Cust comments...Check and advise Smokes heavily on start up
Tech comments...Diag and perform wds koeo, koeo inj test, intake and exh restriction,egr position Fu(page gets cut off) boost pressure high datalogger, vgt pinpoint tests to turbo remove and replace ***(page gets cut off) clear codes after repairs ok.
Recall 05b32
Install label and adjust level
Recall 05b35
Recalibrate engine module per recall instructions
Cust Comments...check and advise excessive smoke and smells raw fuel
Tech Comments.. Test drive and IDS startup check tsbs and one pertains remove turbo and perform test KA failed replace turbo assem and retest after repairs ok
and whats this part for
Part # 6F089 Actuator Assy
Thanks..
Old Apr 14, 2007 | 11:49 AM
fomoconut's Avatar
fomoconut
Recall 05b32
Recall 05b35
Thanks..
I think this means that they replaced the turbo (warranty). A TSB is a "technical service bulletin". So if there was a recall or a new computer flash for your truck they would have performed the work that day. Hope this helps.
Old Apr 14, 2007 | 01:18 PM
kw5413's Avatar
kw5413
...and whats this part for Part # 6F089 Actuator Assy
Thanks..
The Actuator.....
Sorry SDTruckMan....it was just to easy.
Old Apr 14, 2007 | 02:44 PM
SDTruckMan's Avatar
SDTruckMan
Talking
BTW this isnt my truck but one im looking at buying. This is the info they gave me for warranty work that was done.
The first three entries had the same claim#
The last two entries had the same claim#
So am I to assume they replaced the turbo twice?
Is any of what I posted (warranty work) something I should be concerned about, if the turbo was replaced twice that cant be a good thing can it?
Originally Posted by kw5413
The Actuator.....
Dude quit picking on me...
Old Apr 14, 2007 | 02:59 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
5C3Z-6F089-A is the Variable Geometry Turbo actuator.
Old Apr 14, 2007 | 11:16 PM
SDTruckMan's Avatar
SDTruckMan
Drove over to the dealership tonight that had one of the trucks. They were closed of course. Its a nice truck, and optioned out just right.
But got under the truck and found some oil on, I guess what you call the bell housing.
(In the center of the truck, just forward of the front doors)
Wasnt alot but it was there, not sure where its coming from because im not a mechanic and I dont know really what to look for. It was laying on the flat part of the bottom of the bellhousing. It also appeared that the, (what I would take is the oil pan, is black, and just forward of the bellhousing) had some oil residue around the backside of it, in where its bolts up to the engine and in the area of the oil on the bell housing Wish I had a digital camera but dont.
What I did find interesting is that (laying so your head is at the front of the truck, feet at the rear)there is apparently 3 bolts on the bottom of the housing 2 at the bottom and 1 in the upper left of the housing.
The bolt in the upper left of the housing you could turn by hand, it would go about 2 turns backwards and 2 turns forward but you couldnt remove it all the way.
So is this a bad sign and asking for trouble?
Old Apr 14, 2007 | 11:34 PM
SDTruckMan's Avatar
SDTruckMan
Found a picture and highlighted some things... how do I get it posted?
Old Apr 15, 2007 | 07:08 AM
WishIhada7.3's Avatar
WishIhada7.3
my truck had a wet spot or drip on the bell housing till about 24k now its gone and has never showed back up the motors take a while to break in seals and rings...
Old Apr 15, 2007 | 09:19 AM
SDTruckMan's Avatar
SDTruckMan
Guys need some more input on this.
Post#1.. From my very 1st post, and the info on the warranty work.
Am I to assume they replaced the turbo twice. Those entries were on the print out from the dealer for work they performed. The first three entries had the same claim#,The last two entries had the same claim#. 2 different dates-Work performed at different times.
Not sure from the technical wording they use what exactly they did. Good or Bad?
Post#6... Bellhousing drip..and loose bolt. What should I make of this? Would like to post that picture if someone could help me out getting it posted somehow.
WishIhada...this truck has about 33500 miles on it. So it would be broken in by now. Am I to assume the worst if theres oil hanging off it?
Thanks for the help
Old Apr 15, 2007 | 10:11 AM
wb6anp's Avatar
wb6anp
For the picture go to user cp on the blue bar at the top, go to gallery and you can download picture there. As far as everything else I am not a mechanic so I really don't know except it looks to me that they replace the turbo unless one of the cutoff sections said anything about an actuator, that part number is for the turbo vane actuator. Don't know about the bolts would have to go look at my truck.
Old Apr 15, 2007 | 10:27 AM
msgtg's Avatar
msgtg
You didn't give us a year on the truck. The milage doesn't sound bad....
Old Apr 15, 2007 | 10:29 AM
Bushwhacker's Avatar
Bushwhacker
If it is just a small amount or just drips I wouldn't worry. It's a diesel motor and they seap oil. If it is a large amount then I would be concerned but a little drippage is nothing to worry about....
Old Apr 15, 2007 | 10:30 AM
wb6anp's Avatar
wb6anp
the years are in another post, he said they are both '05s
Old Apr 15, 2007 | 11:06 AM
fomoconut's Avatar
fomoconut
My truck is always damp w/ oil in this area, but it never leaves leaves a mark on my garage floor.
Old Apr 15, 2007 | 11:41 AM
WishIhada7.3
if it drips take it in and have them put dye in the oil then figure out where it is leaking from. 6.0's all seem to have the wet bellhousing due to the fact the rear-main and bed plate are all in the rear...both major oil leaking culprits...
