1978 - 1996 Big Bronco
Gas tank question
Old Dec 1, 2001 | 01:18 PM
tite4x4's Avatar
tite4x4
Gas tank question
Old Dec 7, 2001 | 04:13 PM
for_play's Avatar
for_play
Post Gas tank question
I am putting a 75 460 that is carbed into an 86 Bronco that is EFI. I am wanting to change the gas tank and pickup cause they are leaking, alot. Where, or out of what vehicle would I find a 3 5/8" pickup for a carb? Thanks Dave
Old Dec 7, 2001 | 07:41 PM
restorit's Avatar
restorit
Gas tank question
Dave:
Couldn't you, say, use the tank and pickup from an '85 Bronco (or '86) that came with a carbureted engine? An example would be the '85 or '86 351W equipped models? I don't believe these had any kind of in-tank fuel pumps, did they?
Old Dec 8, 2001 | 11:55 AM
for_play's Avatar
for_play
Gas tank question
Im not sure. Thanks for the suggestion. Ill check the 351W.
Thanks DAve
Old Dec 20, 2001 | 11:38 AM
Redbob's Avatar
Redbob
Gas tank question
Since you're not concerned about emissions, you could even use the tank out a '78, which doesn't have the evap emissions vent in the top.
Changing to a fill neck with separate vent hose will let you fill the tank MUCH faster without the pump nozzle cutting off.
And of course you'd need a new fuel level sender/pickup.
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
