relieving fuel presure
Old Apr 13, 2007 | 07:40 PM
OldRed4X4's Avatar
OldRed4X4
Can any provide pictures of where the fuel prusure regulater is and tell me if i have to have a tool to realse it becouse it says i have to in the manual but i dont have the tool but i need to get my upper intake off and get it cleaned cus im having idleing trouble
Thanks for any help
Old Apr 13, 2007 | 08:42 PM
88 f150's Avatar
88 f150
What year, motor size etc. Most pressure regulators will be on the fuel rail nearest the fire wall. There should be a fitting on the fuel rail similar to a tire valve. Screw your fuel pressure gauge to it and relieve pressure. But before you go tearing things apart take the time to be sure everything is in order and pull codes to give you some direction.
Old Apr 13, 2007 | 08:48 PM
OldRed4X4's Avatar
OldRed4X4
sorry a 1987 ford f150 5.0 with a E4OD but i have tried every thing else
(o and i dont have a presure regulater)
Old Apr 13, 2007 | 09:14 PM
Dryfire152's Avatar
Dryfire152
You can relieve pressure by disabling the pump and than run the engine until it stalls.
Old Apr 14, 2007 | 06:14 AM
subford's Avatar
subford
If you have a 5.0 FI then you have a pressure regulator.
Unplug the Inertia Fuel Shutoff Switch and as Dryfire152 said and than run the engine until it stalls.
Fuel Manifold:
http://i54.photobucket.com/albums/g91/subford/Fuel/Fuelmanifold.jpg
http://i54.photobucket.com/albums/g91/subford/Fuel/FPR.jpg
And the FPR:
http://i54.photobucket.com/albums/g91/subford/Fuel/fpr02.gif
Inertia Fuel Shutoff Switch:
http://i54.photobucket.com/albums/g9...SwLocation.gif
Old Apr 14, 2007 | 10:36 AM
Conanski's Avatar
Conanski
You don't need a tool(except maybe a small spade screwdriver) to release the fuel pressure. There's a valve on the drivers side fuel rail(V8s) near the front like a tire valve. Take the cap off and relieve any pressure with a screwdriver by pressing the pintle.
..but i need to get my upper intake off and get it cleaned cus im having idleing trouble
Cleaning the upper intake won't help with idling trouble. If you discover you have a gasket leak or broken vacuum line from this exercise then it may not be a complete waste of time. There's also no need to touch the fuel system to remove the upper intake either.
Old Apr 14, 2007 | 12:45 PM
lostin90s's Avatar
lostin90s
If you need the star (torx ) driver to get intake off go to hardware and get a cheap set of tork drivers for a cordless drill/ screw gun you can get then for $12.00 or less and will have all odd bit you will need . I just tape (its a T40 torx) bit into the 1/4 in socket extension and ratchet.(It shouldn't be that tight. )to loosen remove middle bolt. The sets of torx with square for the ratchet/extension built in won't fit between intake groove. Good luck
