Sponsored by: Real Truck
ck engine light
Old Apr 13, 2007 | 06:27 PM
spdblos944's Avatar
spdblos944
Trailering
ck engine light
I have a 2006 F250 5.4 auto, 3.73ls 4x4. A couple months ago the check engine light came on. When this happened it made the transmision shift differently, it was not as smooth as it was previously and would go to higher rpm before shifting. Dealer said a fuse was blown due to cold weather and replaced the fuse. Two days later check engine light came on again. I took it back to the dealer, when they returned the truck they said the light was not on and that there were no diognostic code associated with it. At times it still does not shift fluidly from 2-3 gear, goes well above 2k rpm. MPG went from 11.8 to about 10. First time post, ck'd the tsb's, no luck. Any help ?
Old Apr 13, 2007 | 06:32 PM
FortyFords's Avatar
FortyFords
When it shifted weird did the speedo bounce around ,stop working????
Rich
Old Apr 13, 2007 | 06:49 PM
spdblos944's Avatar
spdblos944
Trailering
no prob with the speedo
Old Apr 13, 2007 | 06:53 PM
pooldude's Avatar
pooldude
I've been having the same problem for the past 4 months, although the light goes off on warmer days. Personally, I suspect the problem has something to do with crappy ethanol poisoned and/or winter blend gas.
Old Apr 15, 2007 | 05:58 AM
FortyFords's Avatar
FortyFords
If the light returns take it to someplace to have the code read .
this sounds like it could be in the tranny or wiring to it ,sorry to say!
These torque shifts have been pretty good.
Rich
Old Apr 15, 2007 | 06:04 AM
tjmax7668's Avatar
tjmax7668
Does the truck ever crank too long before starting?
Old Apr 15, 2007 | 11:23 AM
spdblos944's Avatar
spdblos944
Trailering
ck engine light
no on the start up question
Bodaddy1969
1997 - 2003 F150
Apr 15, 2014 10:53 AM
skynyrd1911
Aug 15, 2013 07:27 PM
bigTEE56
29
May 24, 2013 06:42 PM
ramrod7373
Jan 16, 2013 08:09 AM
99F150
1983 - 2012 Ranger & B-Series
Dec 1, 2006 10:00 AM
