Sponsored by: Auxito
1997 Ford Speakers
Old Apr 13, 2007 | 05:48 PM
BOBBY6931's Avatar
BOBBY6931
Question 1997 Ford Speakers
Does Anyone Have Any Idea How Hard It Is To Change The 6x8 Speakers In The Front And Back(single Cab) And If I Can Use A Different Size Speaker, Or Should I Stay With The 6x8. I Have Never Tried To Do This But I Can't Imagine It Is Real Hard Any Help Would Be Greatly Appreciated.
Old Apr 13, 2007 | 08:14 PM
torkum's Avatar
torkum
I would stay with 6x8 because they are a direct fit. The factory speakers are held in by 4 screws and 1 wiring connector. Just remember when you are taking the door panels off, don't pull out- LIFT UP!
Old Apr 13, 2007 | 09:15 PM
Ultramagdan's Avatar
Ultramagdan
I agree with that. I tried to install 6X9's in mine and it quickly became apparent that A LOT of work was going to be needed to make it go. Some have done it but once you start popping panels and see it for yourself, you will lean towards staying with the stock size.
Not impossible just doggone difficult to use a different size.
Old Apr 13, 2007 | 10:54 PM
duggyb's Avatar
duggyb
it was awhile ago..but i don't remember my brother have to much difficulty installing 6x9s.....few drilled holes and he was good to go.....he also had 6 1/2's in there as well with just a couple drilled holes..
THNX
Duggy
