Sponsored by: Real Truck
Help
Old Apr 13, 2007 | 05:30 PM
Xtra8ball's Avatar
Xtra8ball
Help
ok fixed lower intake gasgets on 89-f-350 351-5.8 battery was out for few monthsput everything back together plus new fuel filter along with full tune up,now it just cranks fast but wont start im STUCK CAN SOMEONE HELP!!!!!!!!!!!!!
Old Apr 14, 2007 | 06:05 PM
ReAX's Avatar
ReAX
You might find more information in the forums for the older body style, but I'll give you a kick start.
Are you not getting spark, air or fuel? I'd suspect you didn't reconnect something like the coil/distributor or the main engine harness. However it could be something as simple as the fuel pump relay is shot.
Old Apr 14, 2007 | 06:13 PM
350steve's Avatar
350steve
you say you replaced fuel filter,is it in right??may have some air in the line.Turn key on off 3 times.also i heard that some guys changed filters and their fuel pump went out.
6CylBill
35
Mar 7, 2010 08:15 PM
podney
16
Apr 27, 2009 09:44 PM
ChaseTruck754
Aug 21, 2007 06:46 PM
stu37d
Jan 31, 2006 09:30 PM
