Serp belt....
Old Apr 13, 2007 | 04:52 PM
buckshot047's Avatar
buckshot047
Serp belt....
has anyone on here changed one? I see its not in the tech folder...any ideas or tips would be appreciated.
Thanks
Old Apr 13, 2007 | 06:23 PM
wb6anp's Avatar
wb6anp
I just did it wasn't too bad about an 1 1/2 hours mostly trying to find right tool to loosen the tensioner. If you have a single alternator, Remove the "wing" that is just snapped onto the top of the fan shroud, I found that a 1/2" drive ratchet with a pipe on the handle will loosen the tensioner, the tensioner has a clip on it on the right hand side towards the bottom that you will need to push under a tab to lock the tensioner. once the tensioner you can remove the belt, the hardest part of removing and installing the belt is getting it between the tensioner pulley and the crankshaft pulley it goes over the front of the crank pulley but need to go on the tensioner pulley from the rear. It need to go between the tensioner and crank then around the back of the tensioner pulley. once you have it all in place just release the tensioner and install the wing.
