difference in fuel pumps
Old Apr 13, 2007 | 11:43 AM
ghitierman's Avatar
ghitierman
what is the difference in fuel pumps? I have a 94' explorer and when I look for a new pump there are multiple choices as far as amount of fuel pressure it appears. I am either looking to improve millage or gain power do different pumps offer different features. Whats the best one to buy
Old Apr 13, 2007 | 12:22 PM
MisterCMK's Avatar
MisterCMK
What are your options?
Old Apr 13, 2007 | 12:25 PM
marragtop's Avatar
marragtop
Assuming you are going to go with the original in tank pump, I don't think you have that many options. Usually the pumps are specific to the model (4wd vs 2wd, XLT, Limited ..etc) of the Explorer. I also suggest you go with the entire assembly vs. just the pump. It's not that much more $ and an easier install. Also, the Gen I Explorers have a tendancy for the fuel pump fittings to rust out. If you go with the whole assembly it will include the fittings.
Old Apr 13, 2007 | 02:21 PM
MisterCMK's Avatar
MisterCMK
The pump should be the same for each model as the 4.0 OHV was the only motor offered in these trucks
