1978 - 1996 Big Bronco
Steering Problems
Old Nov 26, 2001 | 12:21 PM
AlM's Avatar
AlM
Steering Problems
Old Dec 15, 2001 | 12:24 PM
albertaguy's Avatar
albertaguy
Steering Problems
Driving a 1986 Ford Bronco.
A few weeks back my wife hit the ditch with the Bronco.
Before this happened the steering wheel would sit level when driving straight.
The problem now is that when the wheels are straight the wheel points down to 7 OCLOCK.I have looked under neath and cannot see anything visibly bent.
Has or does anyone no what the problem could be ?
Thanx again in advance for the help
Old Dec 15, 2001 | 01:38 PM
restorit's Avatar
restorit
Steering Problems
If it seems to drive okay, I would say that she probably just knocked the front end out of alignment. Take it into a reputable shop and have an alignment done. This will center the wheel, and if anything is loose or terribly out of whack, they should catch it and let you know. Otherwise, things are just out of adjustment.
Old Dec 15, 2001 | 03:03 PM
albertaguy's Avatar
albertaguy
Steering Problems
Thanx drives fine just that the steering wheel is not in the correct postion, will get an alignment done after xmas and see what happens.
Old Dec 20, 2001 | 10:34 AM
Redbob's Avatar
Redbob
Steering Problems
>see what happens.
You can always center-up the wheel by removing it and putting it back on straightened-up, but that won't solve your problem: your wife no doubt bent something, and you'll only find it by having an alignment shop look at it.
Old Dec 24, 2001 | 09:32 PM
albertaguy's Avatar
albertaguy
Steering Problems
Fixed
Took it in for a wheel alignment $42.00 later all is fine..
Thanx for all the help
